MAP sensor readings with Scangauge?
Old 05-23-2008, 01:49 PM
SilverRam3500's Avatar
OK I guess it is reading in a different measurement then. That makes alot of sense. I was confused for awhile on that but didnt realize that.
Thks!
Old 05-23-2008, 10:57 PM
NoSeeUm's Avatar
Originally Posted by vzdude
While that all makes sense, most scanners do not change the units they are reading from one vehicle to another. PSI=PSI, and "HG = "HG. While I am not 100% familiar with the scanguage, I can't see why it would be any different.
The Scangauge just pukes out a number. It is the ECM that sets the engineering units. Anyways, thats my guess as I really don't know for sure.
Jim
Old 05-24-2008, 04:42 PM
mhenon's Avatar
Originally Posted by ytodd
checked my 02 with my scanguage this morning. 29.5 at idle.
Yep..that's about what my '02 reads. I didn't know the reason for this but start counting everything above this figure to get the "real" boost pressure.
Those with ScanGauge should check all the sensors to get a baseline figure to start from. My IAT and Water temp, for instance, show the same number first thing in the morning. This reading will also be darn close to an outside thermometer. Tells me their both working right. If one of the sensors is off one day I'll know it's time for a change and not have to wait for 6 months of low mileage to tip me off.
ScanGauge is a neat little tool. Get a feel for what all the normal readings are and a bad sensor or reading should jump right out at you.
Mike
Old 05-25-2008, 08:56 PM
JSPulliam21's Avatar
Mine reads 14.X at idle.
Old 05-25-2008, 10:22 PM
OK so we found out the 99 98 and the 2000+ read different.
I thought something was wrong with my 99 and my bro 02.
Old 05-27-2008, 02:22 PM
NoSeeUm's Avatar
This thread got me to watching MAP again. What are you guys seeing maximum on the ScanGauge with or with out a tuning box (boost fooler)?
I am seeing 37.3, but my TST is clipping it.
Jim
Old 05-27-2008, 07:41 PM
bent valves's Avatar
The 98 and 99 MAP will max out at 50 psi. This is where the output voltage reaches 4.5 volts. On 2000 and up trucks the MAP will max out at about 37 psi also at 4.5 volts. So the maximum voltage of 4.5 limits the maximum range of the MAP sensor.
Old 05-29-2008, 08:24 PM
My 98.5 maxes at 30.2 with the Comp on 5x5. My boost gauge read 37 psi.
Old 05-30-2008, 02:21 PM
NoSeeUm's Avatar
Yeah, that would be about 15 psi boost. The TST must clip lower than the Comp, I am guessing 5-10 psi boost.
Jim
Old 05-31-2008, 06:41 PM
Tocapet's Avatar
Mine reads 14.9 at idle. What I don't understand is the wild fluctuations in the MPG. I took a 100-mile round trip with the cruise on and kept getting readings anywhere from 28 MPG to 9999 MPG when I let off the pedal. I have the thing set for Diesel a and 5.9 liter engine. The only time it would pull down to what looked normal was under acceleration. When I stopped it would read 0 MPG and taking off, it would read 2 or 3 MPG. Other readings look normal, temp, RPM, MPH.
Old 05-31-2008, 07:01 PM
You have to set the tank size and follow the instructions for each fillup to have accurate mileage figures. It took me a couple of fillups before my mileage read correctly. Be sure your speed correction factor is set properly, too.
Old 06-01-2008, 07:20 AM
Tocapet's Avatar
Well, I'm NOT filling up with these prices!!! I just put in about 40 bucks worth and drive. Soon as I can, I'm gonna trade this truck for a Corolla!
mechrisme
0
11-29-2011 11:37 PM
SilverRam3500
03-18-2008 07:06 PM
wilnis
12-01-2007 03:47 PM
upjeeper
10-12-2007 01:49 PM
chasd60
05-03-2005 10:11 PM
Quick Reply: MAP sensor readings with Scangauge?
