Manual Transmission Problems
This is a followup to this thread: Good Vibrations!
I've checked the U-joints and they look and feel like they were changed shortly before I bought the truck so that isnt the problem. I've noticed that it only vibrates in 4th at about 1000-1200RPMs coasting....it's also started to make a constant noise in that gear like the clutch is rattling, but I just replaced the clutch and haven't noticed the noise any other time. Also, the "seal" (?) on the back of the transmission, where the driveshaft exits the transmission assembly, is leaking a little bit of fluid. It almost act's like a bearing is going bad...I don't know much about how these trannys are put together so any help with this would be appreciated!! thanks!!
ive checked the fluid recently and it is normal. its not leaking a whole lot, just enough to splatter some on the underside of the truck...there is a bit of play in the prop shaft...what do I need to do?
so you got your clutch installed? hope it went alright for you.
That vibration sounds alot like one I had. Mine turned out to be a u-joint. Couldnt tell it was bad until I actually disconnected the driveshaft from the axle.
1ATony
1A Auto
0
07-26-2013 09:30 AM
ezdemon72
14
07-29-2005 10:05 AM
adamroofer25
08-24-2003 02:31 PM
