LP going downhill what direction?
Started to get a little weak on the fuel pressure. Running 12 idle and about 7 WOT but has dipped down to 5 if the fuel is cold. What direction should I go?
I am thinking about a Holly Blue. Money is kinda tight right now so a Fass is out. IS this the right course of action? I don't really want to tackle that in tank replecement yet and if this pushes more pressure anyway, why would I?
What fittings do I need to do this if I go with the blue? If the LP tanks, does the Blue put enough pressure to run the VP44??
Thanks guys, and if this is in the wrong section, SORRY
Chris
Chris
Chris
Chris
If money is tight.....we still offer the HPFP.....Almost half of the FASS.....
Chris,
I'm kinda in the same boat. My LP is weak, and with my setup (I put in Mach 3's two days ago), I can pull FP down to 1 at WOT. I know I need a better fuel supply to the VP. At first I was researching HPFP and Glacier, but I really don't want to drop over 4 bills if I can fab something up myself that's sufficient. So hopefully someone will post a good DIY set-up parts list. I have seen the blue in action, and it appears to do well.
I've worked with Diesel-Dan on the high idle project, and would love to support his company, but it's gonna make it tight if I have to splurge on the HPFP.
Somebody hep us out please.
Why not a Holley Blue (which you can get for less than $100 at AutoZone) and a Vulcan 'pusher' kit (about $120)? You could buy a second Blue for a spare and still be out for less than the HPFP. Then if you want to upgrade from the Holley later on you can mount it where the Holley was.
Chris
Chris
OK, I know the FASS is the right way to go, and if I had 600.00 or more I would get it. Right now, money is tight and my time is tighter so the Bandaid is fine. Sooner or later, this truck is getting a major HP boost and when it does a fuel delivery system upgrade is gonna happen, but with the mild mods I have, I just need it to get by.
Thanks all
Chris
Thanks all
Chris
Desert Dually
20
12-07-2012 06:20 PM
2500CTD
57
12-07-2004 03:15 PM
Tob
11-07-2003 08:31 PM
