LP died
LP died
Well the stock lift pump has died 82k. i got a pressure check gauge and could not get any pressure pre or post filter.i also did a flow test on it before that, no flow, no pressure so its going to dc tommorow for them to check and fix. i am really glad for the folks that put the tsb's on tdr and folks here for answering the question's and posting info so we can find the tsb's over there. As many of you know dc does not do pressure checks unless the pump fails the flow test.then they put in a new pump if no pressure.They claimed they did a flow test in march and it checked out. i hope i didn't take to many years off the vp44 it has been doing the work glad i had lube in the fuel that helped some.i have 18k left on the warranty.gettin a fuel gauge in right away.I also did a apps reset recently and improved on the mileage over 1 mpg. i will let you know how it comes out.
Tommy93w350
20
11-01-2005 11:07 PM
Rigg4x4
12-13-2002 01:40 AM
Copenhagenjunkie
11-29-2002 09:10 AM
ramlovingvet
10-27-2002 06:33 PM
