Low Fuel Pressure After Walbro Install
I said in my post that the truck primes fine (about 18psi) pump runs like a champ. It is when i start the truck that the pressure drops to -7psi or so on my digital test gauge. Then the truck just dies in like 15 sec. And yes i have heard of FASS, but i chose to go with a Walbro.
So that tells you what? If your pump is running fine and then when you start the truck the pump doesn't run fine, you must need a new pump. Or you could have something hooked up wrong! Did you get the fuel and return lines switched? Other than that I don't know without looking it over myself.
Magnethead
06-10-2012 01:59 PM
wcbcruzer
07-22-2011 05:25 PM
oaborbag
03-10-2008 01:44 PM
bc3
12-01-2007 10:19 PM
