low fuel pressure
Should prolly take this to the performance forum.
May be true if you're trying to keep up with the box. You didn't say how much boost you're pulling though.
Like everything else, it's all a system and the system needs to be designed to your application. Where are you trying to end up? Everything comes at a price. 100+ added hp's worth of fuel is going to require 100+ hp's worth of air.
A sig with your truck specs would help in answering future questions.
I would double check your Edge Juice sending unit with a known working mechanical gauge....i have seen the JWAM's read low under load when the pressure was actually ok. Although you are asking for trouble running a stock pump with a heavy fueling box like the Juice......so...keep that in mind.....
Help fellows, I am new to the diesel world. I am also having lift pump problems. I purchased a 2001 24v 2500 with 100,000 miles. Checked the fuel press and was around 5 psi. Replaced the pump and pressure jumped to 15 psi. Now after about 800 miles has dropped to 4 psi. What is the best way to fix lift pump problems?
OK, so I have a fass pump as you can see by my sig. Twice now I have had low fuel pressure. The pressure dropped from my normal of 14 to 17 down to like 3 to 4 lbs. Both times it happened in the winter while running winter diesel but is is not cold where I run. I added Howes to the fuel and it cleared right up. Go figure.
Joe
jwb600
14
01-28-2008 03:26 AM
bc3
12-01-2007 10:19 PM
mudwisr2
09-25-2007 07:04 PM
Spooler
02-12-2006 11:43 AM
