Loss of power suddenly
I can start up and go, no problem but then a mile or so down the road doing say 60 the engine quits whether or not the cruise is set, I throw it in neutral and let it coast over to the side and the engine goes back to idle. If I push the accellator it does nothing but idle until it gets tired of doing that which is always not more than a minute or so and then the engine will get RPM and I can go ahead and go. The "check engine" light comes on the first time I lose this power and it stays on all day but after sitting overnight it dosen't come on until I lose power the first time. I went about 600 miles to Lexington this past week and it did this about fifteen or more times on the way there and back. I just had a LP and Injector Pump put on it two weeks ago. Is this a throttle sensor device problem and if so where is it located? 1999 2WD Cummins Many Thanks, Sonny
If your check engine light came on there must be some codes. Try turning ignition to on but don't start three times---- on off, on off, leave on the the last time. you should see code in the odometer. I believe it will say something like PCM ---- done Then ECM --- done. If you have codes they will appear before it say's done. Write them down and let us know.
Gary
Gary
It's possibly an APPS problem. It's located underneath the black cover below the dip stick.
This is the resrt procedure: This procedure has shown to help 24 valve ISB engines. It is basically teaching the fly by wire accelerator on these trucks to reread the position of the pedal and it's limits. Most complaints this will help with is poor acceleration, improper shifting, bucking in 5 and 6 speeds. Has been known to increase fuel mileage in some instances.
1. Set parking brake
2. Disconnect negative battery cables on both batteries
3. Turn ignition key to run(to drain any remaining capacitors)
4. Let truck sit for 30 minutes( this is the recommended minimum)
5. Return ignition to OFF position
6. Reconnect both batteries and secure, not a timed event
7. Turn key to run position(not start) and depress accelerator pedal slowly all the way to the floor
8. Allow pedal to return to top position slowly
9. Turn ignition switch OFF
10.Release parking brake
Originally Posted by MadDog01
That stinks! Shows you how much I know! Good luck
Gary
Gary
Originally Posted by ozarkcowboy
im havin the same problem exept i dont coast to the side i just throw it in nuetral 4 a sec and keep drivin would that persedure help any?
cowboy
cowboy
Seems like we go thru fazes on these trucks, when one person starts having problems all the sudden a lot of them start having it. We seem to be getting over the IP problems and now the APPS seems to be the new in thing, gotta be weather or fuel quallity oriented. I'm pretty sure my sensor is giving out on me to.
Originally Posted by Motorpool
Crobtex,
You said you replaced it, What is "it" I don't know anything about these trucks, remember that!
Sonny
Sonny
Look here: http://www.dieseltrans.com/phpBB/viewtopic.php?t=614
https://www.dieseltruckresource.com/...highlight=apps
RHC
08-12-2019 03:32 PM
Commatoze
47
12-23-2003 10:22 AM
