Losing antifreeze outta the side of the block!!
ok wow, i been havin issues here and there with my truck, but now i think i have a bigger one. my truck got hot this mornin and ya, we checked it now after we filled it with antifreeze and its leakin outta the side underneath the manifold. looks like it might be a seal or somethin as its at a spot where its bolted together. wat are you guys thoughts and how hard is this stuff to fix... thanks
Sounds possibly like the infamous cracked 53 block issue. Read about it and see if it matches your issue. You can find the 53 on the block just above the oil pan - sometimes on both sides. It's about an inch tall.
i did pull dip stick and oil looked normal.. ya and i am not very familiar with these trucks. it really shoots it out when revved up. doesnt leak near as bad at idle....
well huh.... i just looked at those pics of the 53 cracked block and that def looks like where its leakin.... i need to check and see if it is a 53 but i would assume it is... shoot...
