Lift Pump Relay...
Lift Pump Relay...
I have been told by several people that I should put a relay on my lift pump since it is back by the fuel tank. Anything special to look out for? I am planning to get a 12v 20 amp relay for it.
Keith
Keith
I'm running a campaign pump relocated by the tank and I've never bother to add a relay... But what kind of pump are you going to run anyways??? FASS or Walbro??? Then I would highly consider it.
You might make sure the fuel pump doesn't start before the engine... Some people have wired in a pressure switch or used the orignal pump leads for signal for the relay.
In any case the VP44 doesn't like to see full pressures during starting...
driftingfly
01-31-2010 07:21 PM
firehawk
08-02-2007 01:59 PM
Superduty
18
02-16-2006 09:25 PM
mazeppa
02-10-2004 06:54 PM
