Lift pump install instructions ??????
Old 04-14-2006 | 01:12 PM
caper's Avatar
Who has the best instructions going to change out the pump , tool list and tips would be great also. Thanks
Old 04-14-2006 | 01:27 PM
CapeBob's Avatar
If you go to the Tech Facts section and go under the 24-valve, 2nd generation section they have a pretty good write up with tools, tips, etc.
Old 04-14-2006 | 07:23 PM
Dieseldude4x4's Avatar
The one that I wrote and submitted is in the tech facts section. It is step by every step and includes taking off the filter housing. I changed enough of them that got to where I could do the whole job in 40 (even along the road in November in Virginia when it was 28 degrees out) minutes run to run. Don't do it any more though, went to the FASS baby. Bye bye LP......
Old 04-15-2006 | 07:13 AM
pboland's Avatar
Lift Pump
I just bought an 01. The dealer I bought it from had to warranty the lift pump and Dodge has relocated the pump inside the tank. It works fine, however I really can't service this configuration as the tank now has to be dropped. What was less than an hour job is now a full weekend for a shade tree. I would recommend reloacing the pump to the frame rail. There are kits available from a number of resources. In addition, Dodge gets $380.00 for the tank kit in my neck of the woods. You should be able to relocate to the rail fo a couple hundred. Hope this helps.
Old 04-15-2006 | 01:03 PM
caper's Avatar
I will relocate to the frame when warr is up. Picked up 3 pumps for $90 CDN each so I will put one on the engine now just incase my vp44 dies while under warr. Thanks guys.
Old 04-15-2006 | 04:50 PM
caper's Avatar
Well just finished Idle at 15, can drag it down to 10 . Hate to change that on the side of the road ,if ya don't have something to stand on your screwed and I'm 6'4 with arms as long as a gorllia. Man the poor break res. it shure takes a beating The pump I put in is one of those kits from cummins well see if this one lasts more than 10 000 km.
Old 04-16-2006 | 12:15 PM
Cyborrg's Avatar
Originally Posted by caper
. Man the poor break res. it shure takes a beating .
I've often wondered if anyone has broken their resevoir off during repairs.
Old 04-16-2006 | 01:45 PM
That's why I carry this baby in the tool box at all times.
http://www.awdirect.com/awdirect/fin...m?itemid=17481
TXJosh
07-05-2008 11:28 PM
PolarisRMK
06-06-2007 08:44 AM
Dodgezilla
08-23-2004 04:16 AM
KenR
02-17-2003 02:13 PM
Quick Reply: Lift pump install instructions ??????
