Lift pump conversion for 01 shown in parts catalog.
Went to run a number to install a lift pump for an 01 CTD and under the usual part number for the lift pump they show another number for a in tank conversion. Got one on the way.
You might want to double check that. It is probably for a gasser. I ran across the same thing. I had a not-very-knowledgeable parts guy, that knew nothing about diesels.
Mike
Mike
actually its possible to relocate the LP to the tank. I know a guy on another board that installed an intank fuel pump from a V10 and said that it worked great.
I thought about doing that a while back with a gasser pump, but never got around to playing with it. What did he do for a regulator on the gasser pump? I'm quite certain he's not pushing the stock 45 psi up to his VP.
J Body, I read this a few years ago...so cant remember the specifics. Just know that it can be done. Sorry man.
Yeah, 45 psi to the VP is too much. I dont really see why a petroleum rated industrial type pressure regulator wouldnt work.
I read on TDR that there is an in-tank fuel pump for the 2nd gens. I believe it is similar to the 3rd gen in-tank fuel pumps. According to what I've read, DC are replacing all warranty LP work with the new in-tank. Here's a link if you're interested:
http://www.turbodieselregister.com/f...d.php?t=135229
Cheers,
Andrew
Cheers,
Andrew
Truck is still under warranty. I just did it's first VP this past saturday. Was going to r/r the lift pump too until I found out about the conversion kit. I'll just not pull the trailer until that is installed. Fuel volume is borderline right now.
J BODY
My truck is going in to Dodge tomarrow to get the lift pump tested
I think it is bad as I am only getting around 10 PSI of fuel pressure @ idle.
I am going to ask them about this part # and see what they say.
Thanks
Thanks
Originally posted by GlennRMK
J BODY
Thanks
J BODY
Thanks
No in tank conversion according to the parts guy, but I wasn't overly impressed with the dealer.
But they did get in today, check it and replace it free of charge. No hassles.
So I can't complain.
Fuel pressure is up now. Around 14-15 idling. 9-10 WOT and 12-13 cruising.
It's true...
Went to my dealer yesterday to pick up an oil filter and asked about a lift pump and they don't even sell them anymore, has a big bulletin about the in-tank conversion for the 98-02 diesels. I still think I'd opt for a new lift pump and RASP though.
