Leaking Water From Converter Oil Cooler
Old 06-23-2008 | 12:13 PM
scroshba06's Avatar
Angry Leaking Water From Converter Oil Cooler
MY CONVERTER OIL COOLER IS LEAKING WATER.... BESIDES BUYING A NEW ONE..... CAN I BUY-PASS IT FOR NOW.... ITS THE ONE UNDER THE TURBO & EXHAUST MANIFOLD....... PLEASE HELP
Old 06-23-2008 | 12:23 PM
Erska's Avatar
I think you can by-pass it. It does not fit with most twin turbo kits so I assume it's safe to be removed or temporarily by-passed.
Old 06-23-2008 | 04:32 PM
scroshba06's Avatar
Thanks.... I Bypassed It. So Far Everything Is Fine..... I Dont Tow Or Anything So I Think It Will Be Fine.......this Is The Best Web-site Period........
Old 06-23-2008 | 07:30 PM
WestTN's Avatar
Without a transmission cooler or a temperature gauge you could get into serious expensive trouble real fast. You know how the tach hovers around 2,000 rpms on easy acceleration? That is heat building slippage. The only safe operation is when you are fast enough to lock the converter. Then you only have the gear and bearing heat to contend with.
Old 06-24-2008 | 05:04 AM
dozer12216's Avatar
Poor ideal bypassing cooler without adding cooler. It is there for reason!!!! You may only have a seal leaking oon tranny oil cooler.
Gmanndodgeguy
16
10-05-2014 07:40 PM
co8tim
02-15-2010 03:08 PM
kev211
14
02-22-2007 03:39 PM
Gene Peterson
01-07-2006 02:32 PM
arhyne
11-29-2005 01:13 PM
Quick Reply: Leaking Water From Converter Oil Cooler
