Leaking rear main?
Old 10-10-2003 | 09:28 AM
FastSS's Avatar
Leaking rear main?
I have a leak that starts at the back of the engine and runs down the oil pan, I think its the rear main, any suggestions
if it is infact the rear main, what is the average price for getting that fixed?
TIA
Old 10-10-2003 | 11:22 AM
thumper 549's Avatar
Re:Leaking rear main?
there are a few other things that could be leaking and i would put them on the suspect list 1-cam plug, cant see it ill the bell houseing is removed
2 oil gally plug (same as above)
gasket on the part that holds the rear seal in.
i would start with a good cleaning 1st so as to make sure its not something simpler
Old 10-10-2003 | 11:59 AM
dodgeman01's Avatar
sure its not the blow by? I was told by a mechanic that my rear main was out : found out it was the blow by tube.
DM01
Old 10-17-2003 | 01:09 AM
FastSS's Avatar
Replaced my oil drain gasket... no more puddles yet
Ceejmo
12-20-2007 11:24 PM
schoust
07-31-2007 11:17 PM
dodgediesel
06-11-2007 09:23 AM
greasy
12-12-2004 10:24 PM
gotmuddy
10-16-2004 02:54 AM
Quick Reply: Leaking rear main?
