Leaking oil but can't find from where.
I have the puke tank replaced with hose to the track bar but every time I park I get a small puddle of oil. It can't be that much because I never loose enough between oil changes to have to add any but it's wreaking havoc on my driveway. There is oil all over everything up under the front end. Any common problem areas out there? Thanks!
did you recently do the switch over from the bottle to the hose?
If so it's probably just the blow by. Mine has done it since i boutght the truck so i never worried about it much. (due to the fact that i have worked around big rigs and have seen it and figured that it was normal)
Two questions. What kind of hose did you use? And is there a low spot in the hose, meaning is there a spot that is lower than the end of the hose?
It is a common seal to wear out, leading to the "always oily front axle." The fix for that is very cheap, just a seal kit, but it's kind of a PITA to do or you pay a lot for labor.
Chances are your vacuum pump is now leaking. I ran into the same thing. Moved and cleaned the puke bottle, still oil leaks, then replaced the seal on the vacuum pump. Genos has a good kit with dvd, seals and drivers. Little more money, but I like the info the kit provides...
http://www.genosgarage.com/prodinfo....OULD_VPRK_9602
I too moved the bottle and replaced the seal on the vacuum pump, both of which helped but after pressure washing everything and watching closely I found that it was leaking around the oil pan seal. Turns out most of the bolts had loosened up... Cheap, easy fix = tighten bolts...
Cummins Guru
Front crankshaft seal, power steering hoses, steering box, oil filter, trans cooler lines. Oil pan gastket and front timing cover, vac pump seal, almost forgot cam sensor housing bolts loosen up sometimes. Just a few places that could be leaking. Vac pump seal available for service read tsb
