Just Replaced The VP44, Now The Engine Stalls
Old 05-06-2010, 05:27 PM
Geico266's Avatar
Well, I finally figured out why my truck was stalling when I put it in gear. This started right after I installed a new VP-44 so I assumed that was the problem. Turns out it was the tranny going bad. It would "grab" and cause the engine to stall. Goerand warrantied the transimssion and when I replaced it it runs fine. No stalling!
There is one for the books.
Old 05-06-2010, 05:30 PM
Geico266's Avatar
Originally Posted by BigIron70
See list of possible causes shown in specific order below. DRIVEABILITY: Check for possible driveability issue that may cause or contribute to engine stall out. Condition may be caused by crankshaft position sensor (CPS) signal drop out. COOLER FLOW: Check trans cooler system flow rate. Trans should be fully warmed up. COOLER FLOW TEST RESULTS: WITH Aux Cooler: Pressure indicated on the gauge should stabilize below (20) psi. WITHOUT Aux Cooler: Pressure indicated on the gauge should stabilize below (30) psi. Higher pressure indicates cooler system is restricted. Repair as required. May require radiator and/or auxiliary cooler replacement. CIRCUIT WIRING: Check TCC (torque converter clutch) solenoid circuit wiring and connectors. Check for shorts to power or ground or chafing (rub-through). Check circuit wiring inside trans pan area. Repair as required. Check for electrical add-on equipment that may be involved. Remove add-on equipment if required If no circuit wiring problems are found replace the TCC solenoid. VALVEBODY: Remove and inspect valvebody assembly for stuck valves / cracks / damage / uneven mating surfaces / loose retaining screws / other. Check all mating surfaces with a precision straight edge tool. Clean and recondition valvebody assembly as required. Torque all screws to proper specification. Replace valvebody assembly if necessary. PUMP ASSEMBLY: Replace trans pump assembly / input shaft / seal rings / torque converter.
Turns out to be the tranny! I replaced the transmission and all is well.
You hit the nail on the head.
Old 05-08-2010, 08:42 PM
Administrator / Scooter Bum
Shovelhead's Avatar
Glad to hear you're back on the road.
Old 05-10-2010, 05:59 PM
Geico266's Avatar
What a PITA.
But, the ol '99 is up and running with a new tranny and all is good again! MAN I love my truck!
Old 07-05-2010, 07:10 AM
Geico266's Avatar
Dave Goerand called and togeather we figured out that if I let the truck idle in neutral for 5-10 seconds the trans will build up enough pressure to hold open the clutches and allow for an easy slip into "D" or "R".
Hope this helps someone down the road.
Old 07-07-2010, 12:40 PM
Junk Man's Avatar
Originally Posted by Geico266
What a PITA.
Glad you love it. I'm getting tired of working on what is supposed to be a 500,000 mi truck. Just about anything will go that far if you dump thousands of dollars into it making it the way it should have been built.
Old 07-07-2010, 01:07 PM
Geico266's Avatar
Good point.
I'm about ready to pull the trigger on a 2011 2500.
Old 11-23-2012, 09:43 PM
cowboykilla235's Avatar
how were you able to diagnosis the tranny? im having the same problem, and it happened right after i JUST put in a brand new suncoast tranny...
Bobby Shirley
12-17-2012 06:37 PM
GCSS
18
12-24-2011 12:03 PM
ClackClack
13
02-24-2010 09:12 AM
Hounddog
02-14-2006 06:33 PM
MIKE,J
08-29-2003 09:26 AM
Quick Reply: Just Replaced The VP44, Now The Engine Stalls
