Just discovered some bad news !!!
Old 01-21-2011 | 08:14 AM
high bid's Avatar
Originally Posted by mr bill
53 block, 182,000 miles and no issues. Don't worry about it.
yep, 205k and still a smile!
Old 01-21-2011 | 08:48 AM
rebal's Avatar
Originally Posted by slatemd
I was told that the majority of 53 failures are attached to standard transmission models. The reason being that one has a propensity to drive harder with slosh boxes. This was what I was told.
worked on a lot of 53 blocks none had a crack, we have a 99 with a 53 with 200k on it no problem at all. I just replaced a 53 block with 280K+- with a 5 spd that towed a goose neck almost everyday , it never cracked, he melted a piston and gauled a cylinder from not watching the pyro. most of the problem is, there thin in that area, a good block will be almost a 1/2" thick where as the 53s are close to 1/8"-1/4". if you tap a 55 and a 53 in the area that cracks the 55 will make a thud sound and a 53 will ring.
Old 01-21-2011 | 05:06 PM
roysleight's Avatar
53 block and 221,000 miles with no problem.
ktpauley
01-09-2011 01:44 PM
shaft
07-20-2010 08:47 AM
westport
13
04-09-2010 06:39 AM
Gotlift01
10-20-2005 10:01 AM
TheMoose
11-13-2003 02:37 PM
Quick Reply: Just discovered some bad news !!!
