Jacobs Exhaust brake
Guest
Posts: n/a
I got ordered it this morning and it will be here Monday afternoon. I am plannng to get my stacks installed next weekend so I will install the E-brake the same time.<br><br>Is there anything that I need to know about before starting the installion? What about tips from those that put there on?<br><br>Thanks<br>Ricki
Guest
Posts: n/a
Re:Jacobs Exhaust brake
[quote author=Ruralmedic link=board=4;threadid=12567;start=0#118817 date=1048272159]<br>No, I don't have one yet, but was wondering where you ordered your ebrake from?<br><br>Thanks<br>[/quote]<br><br>I ordered it from my local Dodge Dealer, I can get one for you at the same price I got mine. I have a buddy who runs the parts department.
Guest
Posts: n/a
[quote author=bulthisl link=board=4;threadid=12567;start=0#119086 date=1048338506]<br>Hauler ;<br>If you have any probs putting it on give me a holler.<br>They are easy to install.<br><br> : Eddie : 8)<br>[/quote]<br><br><br>I will thanks Eddie, I am going to try to install it next Saturday, Hired Gun is coming down and the wives are going shopping so we are working on trucks next Saturday.
Hints. <br>Spray all of your turbo elbow bolts a while before you begin. It sucks to break one off or round it while trying to install the brake.<br><br>When pushing in pin #20, make sure you push it in until you feel it snap in place. It is easier to get at the ECM for this if you remove the fuel filter canister, or loosen the two 10mm bolts that secure it and let it fall towards the drivers side fender.<br><br>
Exactly what Ramflasher said. These are critical points for proper operation of the brake. Once you have it, you will never drive another diesel truck without one.
I have no idea what you are paying for it, but there is a place...<br><br>Mechanicsville Dodge<br><br>where you can order them for about 575 dollars to your door.
I tried to order a Jacobs from my dealer. He said they do not make them for the Cummins. I said BS this is for a 6 speed equipped and they do make them. He said no, I checked the parts system and they are not available. I said "has your dealership ever installed one" and he said no. I said thanks for your help.
Just some FYI. My E-brake kit arrived today, and can't wait to get it in. However, since mine's a "98.5, I'm gonna have to have the ECM checked, and programmed for E-brake function if it's not already there.<br><br>For the required tools in the installation manual, they call for #56 and #27 drill bits. The #27 is merely used as a pilot drill for a 1/2" drill for mounting the solenoid plate. I would think a 9/64" drill would suffice. And the #56 is used to simply push the sealing plug out for the pin connection on the ECM. Here I would think a 3/64" bit, or "similar small diameter rod" would work.<br><br>The part number for the axle shift switch is NAPA #PP6490.
Shilohman
22
11-19-2009 05:13 PM
iflych52
25
10-10-2006 09:25 PM
04-10-2003 05:30 PM
