Its gonna take a real diesel mechanic to figure this one out..
Ok, I have a un-steady idle, not rough, engine does not shake and its not really a miss more like a loss of rythm. Its really hard to describe. I so far have re-set the TPS, checked all injection line fittings, replaced all six injectors with jammer 1's, re-set the ECM, disconnected my edge box, put the map sensor out of my brothers truck into mine, replaced all six injection line crossover tubes, I have an airdog fuel system with a steady 16psi and I am completely out of ideas. Any information and/or ideas would be greatly apperciated. Oh by the way its a 2001, 24v H.O.
Could the VP be operating on an intermittent fashion? There may be some way to check the signal in, to make sure that it is steady, but as for checking the output......??
mine did the same thing but got to the point that it sounded like a huge cam in the truck at idle.. was pretty cool sounding when you have straight pipe exhuast but it ended up being bad ground on ECM, also there was noise from the alternator i wrapped like 3/4" of aluminum foil around the brownish ground wire going to the left battery. This will help with transmission seeking aswell if you have this problem aslo. Then i checked every ground wire and put die electric grease in the connectors that are on grounding cables in the engine bay. This fixed my problem.... ill see if i can actually find the video i made of the truck when it did it.
If the check engine light isn't on it's not bad enough to worry about!
the bigger injectors shoul smoth out the idle, unless there like 150hp over stock or somethin, i know my 275's idle smother than my old dirty stock ones. and thats about the same as the stage 1's.
I dont have any codes...Something that I forgot to mention..The truck does not do it when the engine is cold...In the morning it idle's smooth as glass for the first 5 to 10 minutes then starts acting up. As for the ground wires to the ECM where are they and how many of them are there??? Thanks for the help...
I had heard that the loping idle when warmed up, but not cold, is a warning sign to a possible VP failure. I checked the grid heaters and they appear to be getting hot, plus all the usual fuel leaks.
Any ideas, what's my problem?
Jim
It's not the injection pump - I replaced mine 5000 miles ago, and the new unit tests out fine. I thought perhaps it was the IAT sensor, but I replaced that and although it steadied out some, it's still missing.
92cummisw350le
10-05-2007 09:18 PM
dieslcruisrhead
01-19-2005 09:50 AM
