Installing a custom aft axle tank and selector
Location: Used to be missoula, montana: Now in Sonoma County California
As soon as i get an '02 I already know im going to need more fuel. My old ford carried 60 gallons of fuel and on alot of trips i have needed every bit of that between fuel stations.
Ford (bad word) used a diesel tank selector on thier 1980-97 diesels that is relatively easy to install on the frame that selects both the tank fuel lines send and return and the sending unit wire to used at the fuel gauge. therefor aside from an incab momentary switch i should be able to plumb into the sending unit wire from down at the frame rail and avoid messing with any other factory wiring?
I have no idea where to chase down a fabbed or factory 30+ gallon rear tank that will fit in aft axle under a dodge 02 ext cab SB 4x4 manual tranny. Transferflow does not make anything so im SOL? What about a Ford bronco 33 gallon tank? all i would have to do then is install a dodge sending unit and soder the wire?
Will this setup using a ford tank and pickup work with the FASS or Is it going to be a night mare. Anybody who has done this or something similar with sucsess? I dont know if i want to tie up my bed with an inbed tank but that may be my only other option. Im willing to install the second fuel door in the box side and paint so where do i get my extra capacity
Thanks Guys
Thanks Guys
You can get a 40 gal aux tank from aerotanks. they list it for 95-97, but could probably be refitted to work in the truck you are looking for. link: http://www.aerotanks.com/dodge.html
I have a similar pickup to what you are looking for. I don't want to affect where the spare is, so I am considering having custom saddle tanks built when funds permit. Good luck
I hope that you have somewhere to put the spare. Eventaully I would like two, (for ofroading) so I want to keep the stock location for one, but I will still need to find a plce for the other.
In the last 5 years i have blown beads, torn sidewalls snd ripped the tread off of tires.
I do carry a spare in the bed but mainly i carry a couple of tire tubes, tire plug kits and cans of ether. I can fix tears up to two inch's long any bigger and i install a tube to get me out of where im not supposed to be, the ether works great for reseating a tire. Plus i ussually like to throw my spare onto my trailer which is ussually when i need one anyways.
Dusty
Dusty
