Installing ball joints
Anyone have any luck trying to replace ball joints in 4wd without a press? I do have a torch to apply some heat. Thanks in advance for any comments. BTW this is in a 02 3/4 ton 4x4.
I have been able to get the lower ball joints out with plenty of heat, a nice big hammer and punch to help loosen them up. I ended up using a air hammer with about all of my 250 LBS pushing down on it... However the uppers you will need one I believe. Stay away from the Ball Joint presses at Harbor Freight. I went through 3 of them doing my uppers one time... Junk
I used a loaner kit from Autozone with some galvanized pipe nipples for adapters. Do a search to find out which ones you need. I found that heat didn't help me, but putting the press and adapters on straight and applying a butt-load of torque did the trick. IMO, getting the pressure vector to go straight down (or up) is key....
firebill1720
20
03-05-2010 09:23 AM
Wulzcat
12-22-2009 02:28 PM
Wulzcat
12-19-2009 05:15 PM
bradler
12-18-2008 08:47 AM
