Install mechanical oil pressure gauge
Old 06-15-2006 | 10:44 PM
firesafety3's Avatar
Did the searches and determined that the oil pressure sensor was bad.
Go ahead and laugh, just like the other guys I just about crapped when I heard the ding and looked down to see "0" pressure on the gauge.
So I picked up a mechanical gauge (with mounting bracket, fittings, and nylon line). I also bought some copper tubing in case I decided to go that route, although I just read a thread here describing a copper tubing failure and how the nylon tubing was the way to go, less fatigue.
So here is the question...where is the best place to install the fitting on the engine to route it to the gauge in the cab? Nylon or copper tubing? How do I "bypass" the existing bad sensor so I don't get the "CHECK GAUGES" light or the annoying dinging?
I sure appreciate all advice!
Old 06-17-2006 | 08:02 AM
slim51015's Avatar
you could tap in on top of the oil filter housing.
Jake9612valve
09-14-2011 04:22 PM
grim
08-07-2010 11:46 AM
ryan10
02-19-2007 09:19 PM
Micaiahfied
07-25-2006 11:02 PM
Bluedeviltorque
10-02-2004 12:06 AM
