Injector Connector tubes
When changing out injectors i have found trucks that had raw fuel around the injector down in the bore below the oring on the outside of the injector. Do you at times after several injector changes need to install new tubes or will this fuel even present a problem? This is on a 24valve trucks.
2 ans in one- you 'should' change the 'O' rings every time
and ,2 Norther Diesel up here told me that bosh offers a newer improved version of said tube......and to use it.
I did.-Also the torq is pretty criical if your a anemal you can snork it dwn to far and ruin the seal surface
jstone44720
10-01-2012 08:10 AM
leonesm
04-27-2012 11:40 AM
06RAM2500
02-20-2008 11:00 PM
Cumminsdieselboy
01-23-2005 07:17 PM
