Idle Really Rough!!!
Old 01-29-2007 | 06:54 AM
bart3335's Avatar
Ok so i replaced the vp44 and bleed everything but my truck idles so rough it sounds like its about to die. I have no clue what is wrong with it. i made sure during the vp44 install that everything was installed correctly. what could be the problem? also i installed a fuel pressure gauge. when i start my truck it sits at around 11 then when i drive it sits at 9-10. but if i let it idle for say 10 mins. it drops to 0. it won't climb back up either when i start to drive it stays at 0.
Old 01-29-2007 | 07:09 AM
6WHEELER's Avatar
low pressure pump, maybe. when mine went, it would hold 6-10psi at idle then randomly die and come back. is it the original lp pump, any codes.
Old 01-29-2007 | 07:23 AM
bart3335's Avatar
no its the bd pump. 100 gph. it said bad map sensor. but would that really make it idle that rough?
Old 01-29-2007 | 12:09 PM
RickCJ's Avatar
sounds like time for a new pump and map sensor!
HarleyHauler
19
11-01-2013 05:58 PM
banks twinram
05-18-2010 08:10 PM
cell
01-13-2008 08:57 PM
Mexstan
03-31-2003 02:37 PM
Quick Reply: Idle Really Rough!!!
