I think the fass dealer put the wrong model yr system on my truck.
Old 04-14-2006 | 12:54 AM
ii caan's Avatar
I have been having starting problems when truck is warmed up.
My truck is a 1998.5 24 valve , the fass part number on my reciept is for 1994 to 1998 12 valve.
would the truck even run with the wrong yr system?
The truck runs fine , except for the hards starts after its warmed up.
could it have damaged my vp44?
Old 04-14-2006 | 01:27 AM
high country's Avatar
get your truck up to temp so it should not start well. try to start it to verify that it is being stubborn, if it is run the garden hose on the vp44 for a minute and try to start again......if it starts good......thats bad......bad pump that is
Old 04-14-2006 | 04:58 AM
AlpineRAM's Avatar
If your fass has a fuse that you can access easily try whether it will start better with the fass turned off- the VP44 has some issues with too high fuel pressure while cranking. You can install a relay to turn the LP off while cranking.
I do recommend against the garden hose test because shocking hot cast parts with cold water can have bad results.
HTH
AlpineRAM
rollincoal07
03-01-2008 12:29 PM
RHC
22
11-14-2007 06:29 PM
RedRam410
02-02-2007 10:27 AM
redpoint5
01-18-2007 06:01 PM
Patrick Campbell
10-19-2003 09:22 AM
Quick Reply: I think the fass dealer put the wrong model yr system on my truck.
