Hydralic Help!!!
Hydralic Help!!!
Last night my truck wouldnt go into any gear. I turned the truck off and put it in reverse then started it, the truck started to pull by itself like i had the clutch 1/4 of the way out, my foot was to the floor. Today i replaced the hydralic components and it seems to still not what to go into gear and when i trun it off and put it in gear and start it it still wants to pull a little just like lastnight. any sugggestions would help!!!
Have someone look and see if clutch lever (sticking out of bell housing left side) works when you press clutch pedal. Should move inch or so. Does the lever do a slow creep back to released while holding pedal down?
The hyd. clutch is a bear to bleed, recomend the complete sealed kit.
Is there any noise in clutch while releasing? Could be clutch disc springs or worse if noisy.
whiteknight
03-17-2008 04:21 PM
