how would you know if you need a new vac pump?
Old 08-23-2005 | 11:11 PM
bigthumper's Avatar
a friends a/c wont blow it just blows air out the defrost vents....
is that one way if so.... what would some other things be....
Old 08-23-2005 | 11:20 PM
phox_mulder's Avatar
That is most likely just a disconnected vaccum line.
Check the firewall, and along the cowl.
There should be a vac line there that tees off then goes through the firewall.
4x4 (prior to 2002.5) and cruise control both need vaccum to operate, if the pump was indeed bad, he would have at least those symptoms.
Some years (not sure which) also used vaccum for the power brakes.
phox
Old 08-23-2005 | 11:22 PM
tool's Avatar
Like Phox said.............
If the vac pump wasn't working, his power brakes wouldn't be working either, and they don't stop too good without 'em
Old 08-23-2005 | 11:26 PM
torquefan's Avatar
I have worked on these trucks for years and have yet to see a vacuum pump fail. They will leak oil, but you can reseal them. Your friend either has a vacuum leak, as Phox mentioned, or maybe a failed actuator on the mode door of the HVAC system.
Old 08-24-2005 | 01:36 AM
Supermod56's Avatar
Yep, they will leak like a sieve, but usually always pump. And all the newer trucks have a "Hydroboost" for the brakes, runs off the P/S pump pressure. Vaccum runs the dash controls and the cruise, also the exhaust brake if so equipped.
ARbowhunter7
07-14-2011 10:29 AM
jared thompson
14
05-10-2011 01:23 AM
ARIZONACLASSIC
06-25-2010 08:36 AM
tthomass
20
08-19-2005 10:35 PM
