How often do you change your fuel filter/water seperator
Old 04-11-2016, 11:57 AM
Crallscars's Avatar
I changed to an Air Dog system from the stock filter some time back, I changed them at 10k,I'm at 20k now, how often is too often/not often enough?
Old 04-11-2016, 01:20 PM
cougar's Avatar
Depends on how clean your fuel and environment is. The dustier it is, the more often you should change it. In Arizona, I've had to change fuel filters every fill up the dust was so bad.
Old 04-11-2016, 01:52 PM
SIXSLUG's Avatar
I go 10K, pretty black by then around here....no noted loss of FP at this interval.
Old 04-12-2016, 07:12 AM
Crallscars's Avatar
Thanks, 10k sounds like a good interval, I just have a low fuel pressure light on my truck, something I would prefer to never see turned on.
Old 04-12-2016, 07:18 AM
Received 2,539 Likes on 1,679 Posts
I wait till my FP drops a few PSI under WOT.
I get 30,000 out of them usually, but it is typically wet and not too dusty around here.
Old 04-13-2016, 01:35 PM
SIXSLUG's Avatar
^^same out here. I am probably going too soon, but I get them at a discount so just go every other oil change....
Old 04-14-2016, 02:21 PM
VADSLRAM's Avatar
Once a year or every 25k miles!
starting with right after I replaced my VP because I left a plugged fuel filter in too long.
If you don't have a fp gauge replace the filter before you think you should!
Old 04-16-2016, 07:14 AM
high bid's Avatar
I must be getting really dirty fuel here in Ohio. I have a Baldwin spin-on pre LP and the factory filter and the filters are clogging fast...sometimes after 2-3 fill ups and fairly easy to see psi drop to 4. A real PITA to keep changing them.
Old 04-16-2016, 07:35 AM
You may want to try some Bio Kleen or the like, as the clogged filters might be from an algae bloom in your fuel tank.
Old 04-17-2016, 11:00 AM
SIXSLUG's Avatar
We have the refineries up here so the diesel is pretty fresh plus all the environment protections so every gas station pretty much has new double wall tanks etc...
Old 04-18-2016, 10:43 AM
VADSLRAM's Avatar
Find some new suppliers!
I get easily 10 times more fill-ups before I see any drop in pressure. I'm assuming you're setup is the filters in series. Maybe change the order to get the finer filter second in line. It won't help with the crappy fuel but it should give you a little more time before the flow stops.
Old 04-22-2016, 11:26 AM
Crallscars's Avatar
If you don't have a fp gauge replace the filter before you think you should![/QUOTE]
Sounds like good advice, now I just need to figure out when I should.
I change oil every 10,000, probably do the Air Dog filter & separator the same time
Old 05-01-2016, 07:25 PM
dkenny's Avatar
I change mine the fuel pressure drops and stays down..
some days it run 20psi all day then next day(when its hotter) it'll be 15..
the next morning back to 20.. some days to start at 20 the get down to 15..
at the moment almost 25k miles
you do have a fuel pressure gauge don't you? if not get one!
-dkenny
Old 05-03-2016, 02:25 PM
Mike compton's Avatar
New to the site going off course a little here but I had a fass 150 installed 12 months ago and we were at Tyler state park with our fifth wheel and out of know where the pump burned up at only 10 months of use....luckily it was still under the 4 year warranty...I never changed the little plastic prefilter that came with it I wonder if that might have caused the problem...now I'm scared to go anywhere too far from home...any thoughts would b great!
Old 05-03-2016, 03:28 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Mike, is the Fass plumbed inline with a in tank pump still in place? if so that is something to look at. Those folks that have in tank pumps and choose to put the FASS downstream are just waiting for the in tank pump to fail and ruin the FASS as well.
Make sure it is installed properly with a draw straw or other setup that excludes the in tank pump Some guys get lazy installing them and don't do it right causing a big obstruction when it fails.
Quick Reply: How often do you change your fuel filter/water seperator
