How many miles and maintenance since you got it
I want to start a tread about what truck you have, the mileage and the maintenance done since you got it.
I have:
1999 Dodge 2500 Sport
5.9 CTD
4" lift 36" PJ Dirt Grips
93,000 miles
Repairs since I got it at 80,000:
New front brakes
Fuel filter
oil change
front wheel bearings
new headlights
Tranny service
Transmission Speed Sensor
Thats it.
Dima
I have:
5.9 CTD
93,000 miles
New front brakes
Fuel filter
oil change
new headlights
Tranny service
Thats it.
Dima
2001 Qc Sb 4x4 auto
4.5" lift 35" Nittos
4" exhaust
Scotty 2 intake
74k miles
4 lift pumps (2 factory 2 aftermarket)
Tranny electronics at 20K
A/C system at 37K
All 4 ball joints at 70K
Tranny and track bar need replacing but funds are limiting.
4" exhaust
Scotty 2 intake
74k miles
A/C system at 37K
04 2500 QC
3500 miles first oil change
every 400 miles or so fuel
7800 miles now , getting near 2nd oil change
I would hope that this is a trend.... nothing but fuel and oil and filters when needed
Originally posted by mikmaze
04 2500 QC
04 2500 QC
Dima
02 QC SB 4x4 six speed HO (ETH/DEE for the old timers)
First oil change: 500 miles, Rotella 15W-40
Second: 3500 miles, Chevron Delo 400 (didn't like RoSmella)
Diff lube changed at 10K to Mobil 1 75-90
Added gauges at 11K miles
Added EZ at 12K
Added DD2s at 14K
Switched oil to Redline 15W-40 (the best I've ever used)
Skyjacker D25 coils and Bilstein 5100s added at 21,000
DT Pro Fab track bar added at 21,001 miles (ruined stocker doing coils/shocks)
Wildcat Max-flow at 24k miles
BHAF at 30K
Diff change to Redline Shockproof Heavy at 30K
Fuel filters every 5-7K
Oil every 5-10K, depending
Oil filters always stratapore (important)
Truck runs great, and stock clutch still holds. Only gripe is an air leak in the fuel system that I can't find (truck loses prime when parked nose high). If it's parked nose-lower, it fires right up; nose high and you have to bump it and let the LP run then crank crank crank.
Justin
Added EZ at 12K
Added DD2s at 14K
BHAF at 30K
Justin
Administrator / Scooter Bum
'99 3500 QC auto 4:10 RWD currently 74,000 miles
Averaging ~15 MPG combined City/Highway
Oil changed @ 10,000 mi.
Oil Filter @ 5,000
Lift pump went toes up @ 37,400
Fuel Filter @ 10,000 unless fuel pressure reading flakey
Front Brake pads twice.
Rear Diff fluid @ 35,000 w/ AMSOIL
Trans fluid 1st time @ 30,000 w/ ATF+3
2nd time @ 60,000 w/ AMSOIL
Wiper blades every fall.
(1) Rear Brake light bulb
Top-Off AC Charge every Spring.
Oil Filter @ 5,000
2002 2500 4x4
16 mpg empty/12 loaded
OIL changed every 7-9k miles
fuel filter every 10-15k miles
95,000 miles on it
original brakes,3rd set of tires
3 lift pumps/2 Holley Blue pumps/1 injector pump later
3 sets of injectors {after market}/3 different fuel boxes
everything else is stock, have had to do nothing, except for the
terrible fuel system
95,000 miles on it
2001 2500 H.O Q-Cab Sport Plus 4by4
Rotella 15w-40 every 5000
fuel filter every 10000
carbon metallic brakes
2in leveling kit with 285's on Eagle Alloy's
3 lift pumps
1 Vp-44
1 6-speed due to stupid dealer not putting the fluid back in!!
silencer ring stolen
muffler too!!
edge comp good but 4:10 gears kill it.
I love it, flaws and all!!
3 lift pumps
1 Vp-44
muffler too!!
1999 Bought with 38,000 mile last year has 62,000 now.
Front brakes just because, trans fluid change and shift kit, gauges @ 44,000
EZ Box, Uni Air Filter, 1 lift pump @ 56,000 Cummins bought me the new one.
Oil changed every 7,000 w/filter.
Fuel filter every 5-6,000
Still running original Mich. LTX.
Use some sort of fuel additive every fill up, vp44 don't fail me now.
55,000 mi on an 2002, 4x4.
Non Scheduled Maintenance:
-Stock Auto Tranny Shift Problem (starting in 2nd) at 13,000 miles
-Headlight Fuse Blew @ 19500 miles
-Crome Grill Replaced (pealing) @ 16,000 miles
-Steering Box reinforced (DSS) at 22,000 (done as Preventative Mx)
-Fan Blade thru Radiator at 25,000 miles
-Bigger fuel lines/banjos at 30,000 miles
-Front Brakes at 35,000 miles
-Head Gasket blew at 38,000 miles - due to Bombs and MY fault
-03 Trackbar w/ Solid Steel's Bracket @ 45,000 miles (done as Preventative Mx)
-NO Lift Pumps needed replacing in 55,000 miles, no longer used (FASS)
-Synergyn Racing Oil/Stratapore Filter every 10,000 miles, with Oil Analysis
-Fuel Filter every 7,500 miles, No longer used (FASS)
-Both Differentials & Transfer case every 20,000 miles
-Tranny Fluid, Amsoil ATF, every 20,000 miles
-Tires Rotated @ 5,000 miles
RJ
PS - New Bumper, Grill, Hood, Trans Cooler, A/C Condenser/Cooler and Charge Air Cooler this week. Result of 18 Wheeler backing into me at truck stop...maybe 2 or 3 mph and $4,200 in repairs!!!
God bless NAFTA and the big rigs out of Mexico...cause I won't!
RJ
Location: 13 miles N.W. of Cleveland, TEXAS in the National Forest
- air filters every 15000mi
- LOF Amsoil/Fleetguard filter every 8500mi
- fuel filter every 10000mi (or when gauge gets too low)
- trans flush and filter Amsoil ATF every 30000mi
- replace ft. brakes chk rears every 30000mi
- rear axle flush, Amsoil replaced
- flush radiator every 30000mi
- ball joints, tie rods, bushings, ft bearings, rotors at 100,000mi
- 3 lift pumps replaced during time
- 1 vp44 at 150,000
- r/b tires 10000mi
- belt 60000mi
- p/s fluid 60000mi
- brake fluid 60000mi
- air in the tires !!!
- list goes on and on...
- 1 vp44 at 150,000
- r/b tires 10000mi
- belt 60000mi
- p/s fluid 60000mi
