How many LP can I go through? ....3rd lift pump in 10months
Originally posted by CTD NUT
I change my FUEL filter at every other oil change also
RJ
Originally posted by Gear Poet
The IP on the '01's and '02's aren't as bad as prior years - changes were made to the electronics the front diaphragm and housing. They have a better chance of lasting 150,000+. The LP's are crap. I've had three of them fail in three years, bad check *****, all. For $100, I plumbed a Holly Red by the fuel tank, inline with the LP, and my dealer has agreed to look the other way. No problems in 25,000 miles.
Do something. Don't just wait around for the stock LP to fail again and again.
jlh
I would have thought this would have made you less paranoid about tapping the wire.....now you have seen for yourself that failures occur that have nothing to do with LP fuel pressure and the mechanical part of the VP. Tapping the wire stresses the vane and pump body causing a SLIGHT warpage in the pump body to vane/rotor tolerance because of the large increase in solenoid duration - the solenoid stays open longer during 1 revolution of the rotor to pass more fuel through. On the early VP's the tolerances were supposedly too tight and did not allow for adequate lubrication - these pumps were doomed from the beginning.....installing a wire tap box merely precipitated an existing problem. When these pumps failed, they did not give a 0216 DTC and continue to run - they seize solid and snapped the pump shaft....failure was immediate and without warning - no codes no nothing.
These early VP problems appeared to give the wire tap boxes a bad rep because a box would get installed and the VP would last 20 minutes so the box was blamed.
These failures had nothing to do with the 0216 DTC that indicated VP44 ECU/PC board failures....this is another problem altogether and does not appear to be related in any way to solenoid control and the mechaincal part of the pump. As you know, you can have perfect FP and run all the lubricating additives and still experience an electronic failure because these do nothing except to help the mechanical part of the VP.
So, tap that wire!!
So, tap that wire!!
Originally posted by TRAVIST
Originally it was just for the 3rd gen trucks. They now have a kit that will retro all 24v trucks with the intake pump set up just like the 3rd gens. We just had one in the shop today and gave the guy the option of another lp or the upgrade to the intank set up.
TRAVIST
TRAVIST
Muted User
Here is the TSB site for the 1998, havent seen it there. Didnt see it on the system at school either (lincoln tech automotive).
Moving the lift pump that is supposed to push not pull fluids from every thing I hear works great. I am doing it this week after school, along with a gauge install. I am going with the Carter pump and adding an after market fuel filter as well. Here is a decent set up by njoverkill http://xj.cdevco.net/auto/fuelsystem/ only thing he says he would change and that I am going with is to avoid the gravity feed. I am going to mount the new fuel lines off the stock plumbing coming out of the tank.
No TSB that I've seen yet. Not to say there won't be one I just have not seen anything on it yet. There is just an update in our cataloging showing that there is a conversion available to move the pump into the tank like the late model 3rd gen trucks. If your interested PM me and I will get you the part numbers needed to complete the conversion. My tech just got back from deisel training and they were talking about the conversion there. The instructor at the training said that the new set up has three times as much pressure as the old lift pump set up. MAJOR IMPROVEMENT!
Originally posted by HOHN
I used to think this was true, but my 02 lost the IP (the expensive one) at just 40K miles. It always had perfect FP, and I used lubricity enhancers. It was a mystery to me when it went out, and now I'm paranoid about tapping the VP.
jlh
jlh
Paul
Originally posted by rjohnson
I disagree that they are junk....we just hear about it anytime one goes....
how often do you hear about a 12v lift pump or p7100 taking a dump? never mind multiple failures on a single truck!!
well I went to the dealer yesterday and all the way there idle was 5psi ....as soon as I hit traffic about 3km before the dealer the pressure when back to 15@idle i just cant win with this one
Sorry guy's I miss quoted what my tech had meant to say. The pressure on the new pumps remains close to the same however the volume going to the injection pump is about 80% more than the old stock LP. We just completed a conversion on a 2001 and it went slick. The wiring was simple and installing the pump was a breeze by just lifting the front of the bed up.
TRAVIST
TRAVIST
I heard that the pickup tube in the fuel tank can fall to the bottom of the tank.Where it can suck up trash , grit, sand or other debris.The screws apparently rattle themselves loose allowing the tube to fall to the bottom, where the srceen rubs through rather qiucky then enters that trash through your entire fuel system.Then the damage starts first at the lift pump.
