How to get tow'd?
How to get tow'd?
Hey guys, Im having wiring and fuse issues and need to tow my truck home.
Just wondering if I can put the key in run position, put truck in netural and go, or do I have to disconnect drive line or anything like that.
I know some vehicles will burn stuff up if just in neturtal, but will mine??
TIA Ian
TIA Ian
Location: This Nazi state of California 2nd home Gilbert AZ under God
Disonnect the drive line. There is no rear pump on the transmission so no lube. For what it costs to repair I would not tow more than a mile if you choose to not take it off.
TIA Ian
TIA Ian
Since you are just going a short distance I wouldnt bother pullin the shaft. I used to tow stuff all the time just a couple miles and never pulled it, never had any problems. If you are worried about it, it only takes a second to undo the 4 bolts. Take a ratchet strap and strap it to the frame so you dont lose any fluid out the tailshaft.
When my VP went out the tow truck driver would not tow unless I let him disconnect the driveline. As stated, there is no pump unless the engine is running so you'll likely do damage.
Short distance I wouldn't worry. The xferC has its oil pump run from the output shaft to the rear axle. Slow speed and there should be enough residual lubricant in the rear bearings in the transmission to keep the bearings lubed. IF you wanted to be sure, you could put the tranny in Park, the TC in neutral and pray it stays that way all the way home (not my preference).
1 Post
Transfer case in neutral and trani in park. Transfer completely disconnects wheels and drive lines from trani. Same as towing a jeep or anything else with neutral transfer available
Not the same.....and anyone who feels that they are positive enough to tell someone otherwise should be willing to help foot the bill for any repairs.
