How can i keep my cummnins running longer?
I have a 1998.5 24v dodge, and i am wondering what i can do for preventitave maintence on the truck before somthing happens on the engine.
I have a little blow by and it runs good but smokes a lot on startup for about 2 mintues
Fuel pressure gauge for starters. Regular maintenance and a keen ear. You'll soon learn whats normal for your rig and what's not.
See your other post as for the smoking issue, not normal.
If your really worried about the blowby, you can always do a compression test to see how well the rings are actually sealing. But regular maintnance will help the most. Don't forget about maintaining the coolant system too. I'd highly recommend gauges as well, most importantly a fuel press. gauge on these trucks. Do a search on lift pumps and VP-44 injection pumps, and you'll see why
After market fuel & oil filters , systems , nothing bigger that 5 micron , this is where smaller is better , 2 micron or sub micron , Spinner filter
for the other fluids & lubes , flush every 20,000 , brake fluid , coolant , gear lubes , grease's .
Oil analysis to see things coming & going , when to change .
Quality parts / filters / fluids - pay a little more up front , not a lot later .
Also, change your brake fluid every 2 years or so. It soaks up moisture
I have Prestone Heavy Duty coolant in mine. Its purple in color and has Penray additives in it. I can't remember the cummins requirement # offhand, but the stuff I have meets it. Pretty much, you want coolant that meets the cummins requirement and is a low silicate formula. A lot of guys just run the Fleetguard stuff though. As for brake fluid, I'm running the Valvoline syn. stuff.
I use Shell Rotella ELC coolant. It meets the CAT EC-1 standard, and it has some seriously severe requirements. It contains no silicate, and is an extended life coolant good for 5 years 500k miles. Amsoil in the diffs, trans, and transfer case. Napa Heavy Duty DOT 3 brake fluid, changed yearly. Shell Rotella 15w-40 engine oil and Fleetguard Stratapore filters. Every tank of fuel gets 2 stroke oil or Stanadyne Lubricity Formula. Every oil change I run a quart of Power Service Diesel Kleen to clean up the injectors and fuel system.
That takes care of the fluids, but I forgot the fuel system. Yikes! First of all, you need a fuel pressure gauge. Then, once you see your fuel pressure is dangerously low, get an after market lift pump, draw straw, 3/8" or bigger fuel line, and a big line from the filter to the injection pump. This will assure you have a way to monitor fuel pressure, have eliminated all restrictions in the fuel system, and feed the injection pump a high volume of fuel at the proper pressure. This will keep it alive as long as it wants to live.
What are the benefits of hte draw straw? I am installing a fuel boss and big line kit from Glacier but am not familar with this. Do I need it for my system or is what I am doing enough? Dont mean to hijack this, but wanting to get this right the first time.
The Draw Straw is a requirement for anyone that has the in-tank pump, but not necessarily for a person with a standard lift pump. The Draw Straw eliminates the restriction between the lift pump and the tank. Your lift pump will not have to work as hard to suck fuel from the tank. I bought a draw straw to eliminate this restriction, and to completely bypass the stock pick up.
ldornak
16
01-30-2010 02:17 PM
Duallydog
04-23-2006 12:33 AM
00turbo
06-15-2005 07:54 PM
