Hotrod VP44
Hotrod VP44
I just got my Industrial Injection Hotrod pump installed today, I took it out for a ride and wow does it run!! With the comp off it seems to have at least 50 more hp than stock. The comp still adds lot of fuel up thru the levels just as strong as before. It will even blow a nice haze out now, never got much smoke before. I pulled out in 2nd and hammered it and the rear tires broke loose and spun till I went to 3rd. Never could do that as easy before either.
I'm really impressed with the HR VP44!!! I should be over 300 rwhp now!!
This was my 1st pump install, I took my time and had it out in 1.5 hr. and back in 1.5 hr. changed the pump cover, blew out the lines, and cleaned up the oilly residue, 3 hr total and not a very diffilcult job.
Originally Posted by Andy505
are there any special tool needed to change the vp?
If you have the tools and can change your oil and brakes you can easily change the pump!
It has the same warranty as the rest 1 yr. and unlimited miles. Only thing if you pierce the pump wire and the electrics go out no warranty for that. Or if you don't have fuel pressure.
dieselguy71
04-16-2008 06:41 PM
