homemade pressure tester?
Old 07-12-2005 | 02:44 PM
2 busy's Avatar
Ben trying to find the picture of the homemade intercooler pressure tester. Cant remember what all the materials were.
Old 07-12-2005 | 10:16 PM
2 busy's Avatar
does anyone remember where it was? i know i seen it on here but cant remember which forum
Old 07-12-2005 | 10:48 PM
fschiola's Avatar
Here's what you might be looking for.
Click here
Old 07-12-2005 | 10:55 PM
rockwithjason's Avatar
It's probably rolled off the boards by now. The components you need are available at home depot
1 4in to 2in rubber coupling (found in the plumbing dept, fernco is the brandname)
1 2 in pvc end cap
1 1/8 x close brass nipple
1 1/8 brass tee
1 0-40psi gauge
1 male air tool coupling
drill and tap the 2in end cap for 1/8npt threads. Using teflon tape as the sealer, thread the 1/8 brass nipple into one of the straight thru bosses of the brass tee, thread the male air tool coupler into the other straight thru boss of the brass tee. Thread the gauge into the remaining boss of the brass tee. Thread the whole assembly into the 2in pvc end cap. Insert the 2in pvc end cap into the 2in side of the rubber coupling and tighten the hose clamp. To use, remove the intake hose from the turbo. Install the 4in side of the rubber coupling onto the compressor housing of the turbo. Attach the male air tool coupler to compressed air regulated to 30psi. Use a squirt bottle full of soap bubbles to find intake system leaks. Caution: if you run to much air pressure or you don't secure the fitting to the turbo well enough you could have a blow out and injure yourself. Be careful.
Old 07-13-2005 | 12:45 AM
2 busy's Avatar
that will work, i thought the air tool couplings were 1/4 in. will have to see what i can find . just wanted to make sure i had a list . I seem to be getting forgetful.
Old 07-13-2005 | 10:57 AM
infidel's Avatar
On my tester I skipped the tee and just tapped two 1/4" ports in the cap, one for the gauge and one for the air fitting
Old 07-13-2005 | 07:13 PM
2 busy's Avatar
I could'nt find a 1/4 npt tap or half the other fittings in this one horse town. got a 4in cap and gonna try drill a hole and pull a valve stem in. havn't had time today to try. think i have a 4in fernco out in the shop.
Old 07-14-2005 | 02:45 AM
95ram's Avatar
All I did was used was 4x3" PVC, 4" end cap, 4" rubber cuppler, and male end. Glued the cap to one end of the pipe and used the coupler to connect to the turbo. Used the guage on the A pillar.
DO NOT GO OVER 10PSI. I did this and it poped of. Sounded like a shot gun.
ldornak
08-19-2008 11:23 PM
bobem12
04-09-2008 11:18 PM
06megacabman
02-28-2008 11:44 AM
wcbcruzer
08-21-2007 11:44 PM
