At home trany swap
At home trany swap
I am thinking about swaping out my auto trany at home. What do you guys use for a trany lift? Did you need to jack up the truck? Any other tips?
Thanks Bob
Thanks Bob
I use a floor jack with a custom "pan" to hold the tranny. You could just use a piece of wood if you are careful. I did put the truck up on jackstands to make more room to move the tranny around.
I did it twice in 6 months. Its not that bad but you will use some new language. I didnt have to jack my truck up at all cuz its high enough the way it is(see sig). But i would sugest you put the front up on stand about 5 inches. For the cross member you need to spread the frame rails a lil, so having a port a power spreader is the key. Takeing out your down pipe gives alot of room. A buddy to help with lifting in and out part helps alot. these trannys are clumsy. I just used a floor jack with a pieces of wood and a strap too lift and lower the trans.
That's how I installed my Muncie 4 speed on my 67 Rally Sport when I was 19. Never again!
Dieselrob,
I see you have a georend Bros trans, was it worth it, with all the shipping expense? Why didn't you go local? I am thinking of doing the same thing, any ideas?
Thanks Bob
Thanks Bob
The truck in my sig has a Goerend and in my opinion it was well worth it to have it shipped. Didn't go local because the only good tranny builder around here is Haisley's and they're pricy$$$.
jmccart
48
07-23-2008 12:34 AM
