Holset Question
Old 06-20-2007, 08:24 AM
Need95-00CTD's Avatar
Why do you insist on Stainless?
Use a stock HX-35 exhaust flange (5-bolt peice as you call it), it already has a 3" V-clamp outlet on it. You can find an whole junk HX-35 in the freebies section of the classifieds, get it, use the part you need, and sell the rest, or put it back up on here for free.
Old 06-22-2007, 01:21 PM
35psitsi's Avatar
Well I had the flange designed, put into CAD and cut on the waterjet. It's gorgeous 316SS. I'm likely going to be cutting 30 more of these in 304 stainless, as there is a market in the import industry with these turbos. Let me know if any of you guys are interested. I'll be posting pictures tonight.
Old 06-22-2007, 02:52 PM
Well good luck getting the bolts out of that when you need to take off te flange, matching SS with Mild Steel is a bad idea, your heat transfer characteristics are not as close as most people assume. Steel and Stainless don't expand at the same rate, and Stainless may seize if you use the wrong bolts, how did you have a flowjet cut the V-band groove?
Old 06-23-2007, 04:58 PM
35psitsi's Avatar
SS bolts are used with SS hardware (washers and locks). I'll post pictures later.
jdr160
07-20-2007 12:20 PM
toyota31
12-22-2006 11:55 PM
turbo2001rt
11-20-2006 02:11 PM
fahrfrumwurkin5
03-13-2005 03:38 PM
fahrfrumwurkin5
01-08-2005 04:28 PM
Quick Reply: Holset Question
