Hollow thumping sound coming from rear end.
I just came back from a trip to OK and back pulling an empty 4 horse up and loaded back. Now when I back up I can hear what sounds like a hollow thumping coming from the rear end. Any ideas as of what it could be? I am praying it isn't my rear end getting ready to go out.
Check the cheap/easy stuff first.
Have you looked at the plastic inner-fenders lately?
Those Oklahoma roads can loosen up the plastic fasteners, and the inner fenders can make more noises than a Mocking Bird!
Another "thought". Do you have the limited slip differential? Do you have the friction modifier in it? Could be the clutch plates chattering (mine sounded a bit like a thump when I didn't have the stuff in).
~Rob
~Rob
Checked everything and everything seems good. I noticed it does it when I am turning. When I have the wheel turned to the right in drive and reverse. Doesn't seem to do it any other time. Yes I have the limited slip.
My rear end knocking vibration was the carrier bearing on the 2 piece drive shaft had failed and come out of the carrier. Check it if you have a long bed. They are prone to fail after 100k miles.
FlaCracker
03-16-2010 10:41 AM
clemson725
01-27-2010 04:32 PM
Gear Poet
06-19-2009 10:11 AM
Gear Poet
06-18-2009 05:44 AM
Rock Hauler
02-15-2007 06:27 PM
