Holley Pump Users Chime In Please...
I installed my holley blue pump about 2 months ago now. I first got it running and the pump sounded loud when first started but a normal sounding loud. And this weekend it got louder with a different tone. Like a metal sounding tone. It's weird and i can get audio if needed. But did any other holley users have problems with there pump's sound changing after a while?
I have been running the holley blue pump as a stand alone pump for about a year or slightly longer right now. I see around 14psi at idle, can pull down to about 10-11 @ wot. Have had no issues with pump at all. Took care of noises pump made by inserting a piece of rubber between the mounting bracket of the pump and framerail. I only hear mine when the pump cycles once the beast is fired up the rattle hides the sound of the pump. Mine's located about 2 feet in front of the tank.
Registered
i have 2 holleys and both of them are pretty loud with the inital key bump. But both of mine together cant be heard over the engine and stacks. (no problems out of either so far) 24 psi idle 15 WOT
I have it running as a standalone pump and it is mounted on the frame rail about 2 feet in front of the tank. The noise it's making is just louder than normal. I will get some video of it tonight and post up. I hope this fairly new pump is not going out already.
I made it home tonight from a little drive and the truck run's just fine but i don't hear the pump kicking on at all. Even bumping the ignition i don't hear it taking off and priming.
Has anyone ever warrantied one of these or do i have to just purchase another?
I've had a Holley blue as a stand alone pusher for about 10,000 miles. 14 psi and not below 11.5. I think the biggest improvement to the system is getting rid of the banjos. I took off the filter housing and tapped the threads to 1/4 npt. Then used 3/8" barbs and 3/8" fuel line from the pump (on frame near tank) to the filter housing then to the IP. I left the banjo on at the IP but drilled out the holes to 3/16". Now when I change filters, I bump the starter 3 times and the truck fires right up. Never had that before. Always had to fight to get it started. Even when I had two pumps and 25 psi.
I even see a difference every time I start the truck. When I turn the key on and wait to start, I hear the pump for a second and see about 6psi for a moment. When it fires up - 14psi steady.
How long will it last? I'll find out, but I've never been happier
Not to threadjack, but can anybody post a pic of their holley set-up? About 10,000 miles ago my VP went out, had the dealer change it under warrrenty, they said my lift pump was fine(but I knew it was bad) but I said okay and I was thankful I didnt get the in-tank pump. Went home and instantly bought a vulcan big line kit all the way to the VP inlet, also bought a campaign pump for 59.00 from the local cummins dealer, here I am 10000 miles later and my carter took a dirt nap. Went and bought another cummins pump for 59.00, now I know these pumps are junk, but im just not ready to drop the green on a FASS II, which is eventually what I want. Thus interested in the holley if it will last longer then 10k I be in good shape!
www.stamey.info/truck/fuelpump1.htm
That might be a place where you can find pictures of the holley setup. If not just search in google and that's where i found one last night.
I just checked my purchase date and i have had the fuel pump for exactly one month. Kiss My A**
This is going to be expensive if i do this once a month.
