Which Holley fuel pump to get??
I want to replace the lift pump with an aftermarket. Which one by holley is the dependable one? The marine blue, the marine black, standard blue or what. Man I am confused already......
Re:Which Holley fuel pump to get??
There have been some quality issues with the Holley line of fuel pumps lately. At least this is what PushRod said. I do not know if this has been resolved yet or not. I'd recommend the Performance Engineering pump, but problems with them have surfaced and PE has pulled them from the market until the problems are resolved.
At this point it's a crap shoot for an aftermarket pump. I have a Holley Blue on mine, but I bought NOS off of Ebay so it predates the quality issues.
Chris
Chris
Top's Younger Twin
I had two dud Holley Blacks [my new truck is black]
and a failed PE 4200.
I have had the best luck with a Holley blue
Had to use it when the Holley black [my new truck is black] was not available due to quailty control issues.
Then after all the hoorahs for the PE 4200 I had a custom mount made and used it with our Wildcat fuel system...it lost pressure down to 5 at cruise and near 0 at WOT.
Needless to say, the Holley blue [my new truck is black not blue ;D] that was/is in the factory position and is running strong again and has about 30,000 miles on it now.
My fuel pressures are 13 at idle, 10-11 at cruise and never drops below 7 at WOT and that was with the TST Powermax 3 Comp on level 9, stage 3's, B1 Kwik Spool and the Scotty Air that SUX COOOOOooooOOOoOoOooooL AIR! The pressures would recover to 10 even at WOT after a few seconds. Black
Did I mention what color the new truck is? :
![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
Location: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=TXRAM2 link=board=4;threadid=17731;start=0#msg166257 date=1059654159]
Scotty did you say you new truck is black :
geeeesh I sure hope they ship the correct color ![Shocked](https://www.dieseltruckresource.com/forums/images/smilies/shocked.gif)
[/quote]
Hmmmm, I was sure that I saw the order sheet at Nipawin Chrysler and it was Mary Kay Cosmetics Pink that was checked off.
![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Rod
[/quote]
Rod
Top's Younger Twin
[quote author=Push Rod link=board=4;threadid=17731;start=0#msg166311 date=1059661214]
[/quote]
Rod
[/quote]
Shut up pinhead.
;D
[/quote]
Rod
[/quote]
Shut up pinhead.
;D
Scotty..I'm confused?? ??? is your new truck Black & Blue, or is it Blue with Black, or plain Black with Blue seats, or plain Blue with Black seats, or Black on Black or Blue on Blue? :
Or is it plain Pink? ;D
If you have a blue pump that worked fine, why didn't you just paint it Black for the Black truck, instead of buying 2-Black pumps that didn't work on the Black truck?
AlCorr
114
02-11-2009 02:32 AM
Texaschevelle
26
11-16-2007 08:08 PM
linetrash75
33
10-27-2005 12:28 PM
chucktownsend5
14
03-31-2005 12:25 AM
Moose10
10-15-2004 03:56 PM
