Highest miles on original lift pump?
Old 02-13-2007 | 05:57 PM
lumpy_63's Avatar
Who has been able to make their original lift pump last the longest? I am just curious... Mine has about 61K on it now.
Old 02-13-2007 | 06:31 PM
ken-c's Avatar
First replacement at 147k and second at 177k
Old 02-13-2007 | 06:49 PM
CoastalDav's Avatar
Ken; You got me beat. First one changed out at 95,000. Still have the second one in. Got 168,000 on the truck now. Original VP44.
Dave
Old 02-13-2007 | 08:04 PM
matthopp's Avatar
Our 2002 work/field truck, 235K; no cummins problems, just that auto tranny. No fuel pressure gauge, but our mechanic says he is going to look at the lift pump since the fuel filter housing isnt filling like it used to.
Old 02-14-2007 | 08:55 AM
Commatoze's Avatar
My lift pump was still going strong at 128,000 when my IP died. The dealer who replaced the IP and would only warranty it if I had the LP replaced at the same time. So far, the new intank pump has been fine.
Old 02-14-2007 | 09:41 AM
DRKelly's Avatar
Mine appears to have just taken the plunge last Saturday. 175K on the original.
Old 02-14-2007 | 12:05 PM
Codyboy's Avatar
215,000kms on original LP and IP hopefully i didnt just jinxed it
Old 02-14-2007 | 04:06 PM
nitrousn's Avatar
83,000 and pumping fine.
Old 02-14-2007 | 04:20 PM
duck6's Avatar
147,000 and still going strong
Old 02-14-2007 | 04:43 PM
smokindog's Avatar
My stocker died at 88K, I replaced it with another stocker under warranty and that one made it until 159K when I put on the FASS. I'm pretty sure the second one was on its way out because I lost my VP 10K miles after putting the TST on. I don't even think about either pump failing anymore. I have a solid 15psi at all times and check the incoming fuel temperature with the DRB a few times in the summer.
Old 02-14-2007 | 05:05 PM
TorqueJunkie's Avatar
Mine took the big ole dump at 86K which was followed promptly by a VP change. I am pretty the VP wasn't needed but DC did it under warrenty so I didn't complain.
Old 02-15-2007 | 10:16 PM
m.rehme's Avatar
Mine acted funkey for years, it was running but the check in it would stick open and not show fuel pressure. I changed it out at 218,000 - have 297,000 on the original VP44.
Old 02-16-2007 | 12:39 AM
bentwings's Avatar
105k The first of strandings. pouring rain cold. 65k on #2. 14psi at idle 10 WOT after the filter.
Old 02-16-2007 | 06:01 PM
y2kram's Avatar
Did it before it failed
I replaced mine at 150K before the pump actually failed. I tested the pressure at the IP and saw 7psi at idle. I replaced it immediately before it completely went out (taking the IP with it).
Old 02-16-2007 | 08:19 PM
ridepayson's Avatar
156k
Just changed mine last night, 156k, I am hoping I caught it before it killed my IP. I went with the aeromotive pump, 15 psi idle, 15 psi WOT...... so far, so good.....
Quick Reply: Highest miles on original lift pump?
