High Idle Speed
High Idle Speed
After drives of 30+ miles at 60+mph my idle speed jumps to 1000 - 1100. Is this normal or ok if not what is my problem. Thanks.
Year and number of valves in the engine would help immensely.
Since you posted in the 24 valve section, assuming you have a 24 valve electronically controlled engine.
phox
phox
1 Post
Re: High Idle Speed
Re: High Idle Speed
Fill in your sig so everyone will know what you drive. Geez, I thought I had him trained better than that!
Don't even get me started on your problems!
How many drinks are in you when this happens? Are YOU sure your foot is not on the acc. pedal .
He has an 01 3/4 ton 6 speed.
jmccart
06-12-2007 02:12 PM
whtractor
05-23-2005 11:35 AM
