high idle/remote start
i have had the high idle feature turned on in my truck, it works except when i use the remote starter it shuts off the truck when the idle ramps up. is there any way around this? no use having the two if i cant use them......
If it is a tach sensing unit it might turn off. You could set it for voltage sensing which would read off of your alternator. Mine works fine with high idle. The tach sensing feature also has a threshhold adjustment so it will allow more tolerance. This is true with DEI and Audiovox units.
robert78.5
11-10-2013 06:33 PM
Undertaker
10-26-2009 03:02 PM
GotStacks
16
03-06-2009 02:22 PM
jmccart
06-12-2007 02:12 PM
DFD536
08-05-2004 11:01 AM
