helper/pusher pump by the tank.
i've heen having FP problems and i have a extra camp. pump i was wanting to put back by the tank. where do i get the fittings, plug, and so forth. and do i need a oil pressure shwitch to delay the first pump to avoid hard starts or what?
Registered
cut the steel line under the cab, mount the pump on the frame, use 3/8 fuel line to hook it up. now some use the stock pump wire to fire a relay to switch it, some have used a oil sending uint, BUT most just use a (key-on) hot wire and no relay to run it. I like to use the power window relay in the fuse panel on the side of the dash, and get the power before it goes though the relay . you will run about 20-25 psi, and shouldn't have hard starts, or any problems
to use 3/8 fittings you have to re thread the metric threads in the pump to npt, very easy... i have done several , a tap will be cheaper than buying metric hose barbs,
I've done the same thing. Just be sure to remove all metal shavings. I removed teh top of the pump and cleaning everything inside as well. Very easy.
Geno's garage has a relocation kit for under $100. I bought one an really like it. A little patience and you can do yourself.
http://www.genosgarage.com/
My campaign pump crapped out and now using an Aeromotive AE11203. It idles at 16 psi, 12-14 at 65mph and never below 8 psi at WOT pulling 10K lbs
http://store.summitracing.com/partde...5&autoview=sku
I use one on the veggie side as well. Really good pump for the money!
Q
Q
John_P
68
12-02-2011 10:22 AM
yarddog
11-10-2005 05:23 AM
