HELP Tranny Trouble
Old 10-22-2009 | 07:15 PM
bowhunter57's Avatar
From: I live in Bernville Pa but where I want to live is Colorado
HELP Tranny Trouble
I just bought this truck last week an already, tonight on the way home from the mountains when I pull out it don't want to shift out of low if I play with the throttle an sometimes shift into nuteral an back to drive it will shift an then go to hight an lockup but next stop light it is the same thing unless I don't come to a complete stop then it will stay in second, I think, an then it will shift fine into 3rd any IDEAS Thanks in advance. what does it cost to get a trans redone for this truck OH Sorry its a 1998&1/2 Qcab 4x4 auto short bed thanks again
Old 10-22-2009 | 09:57 PM
CoastalDav's Avatar
If you have not already, check the tranny fluid with the engine at normal temp, in Neutural. I saw you just bought the truck. If you owned a GM before you'd check it in park. If the tranny is full, I would seek some professional advice. It might be something simple like a band or valve body problem.
Dave
Old 10-22-2009 | 10:42 PM
thanks for the answer I had one of these before an I know about the hot an neutural thing I've been reading the search on this an may have found something , How about the Trans output shaft sensor,,,, anybody second this thought. Thanks
Old 10-23-2009 | 12:21 AM
rebal's Avatar
Might check the ground wires, a bad or loose ground can make the trans do all kinds of things . on Sunday I had one in the shop doing something similar and it was the ground wire loose on the right side fender, the one from the battery
Old 10-23-2009 | 05:23 PM
Just a heads up took it to the shop today and he dropped the pan, it was so full of metal that i'm going to add it to the scrap pile for the weight Trans is shot. As I type this they have it on the bench and I will have it back monday late he said. He has everything in stock, Billet converter, valve body, everything heavy duty.Plus he will Flush the lines and the Radiator which a lot of places forget to do. Price not sure yet but I need the truck
Old 10-23-2009 | 08:20 PM
dozer12216's Avatar
And now ylou know why it was for sale.
Old 10-24-2009 | 04:32 AM
YEA I bought it from a COP never trust a Cop
Old 10-26-2009 | 09:31 AM
More Bad News Help Please I Need A Trans Case Mine Is Broke 47re Needed Asap Thanks Bob
Old 10-26-2009 | 07:55 PM
DodgeRamdiese01's Avatar
I just noticed you live in bernville I live in Robesonia, if you need a hand working on anything i may be of help, as far as a trans case I'll ask around
Old 10-26-2009 | 09:52 PM
Hay I appreciate that I'll keep you in mind from now on. I did find a case an it should be here by UPS before lunch tomorrow I ordered it next day air. my phone # 484-256-1197 if you need any help give me a call also.
Thanks Bob PS I just moved to Bernville from WOMELSDORF
ridlangus123
12-30-2013 09:36 PM
Black Dog
12-03-2009 09:18 PM
phantom 309
10-09-2008 08:50 PM
~Angry Tractor~
13
10-25-2006 11:02 AM
MARKY MARK
01-16-2004 04:49 PM
