Help me decide
Help me decide
Well I have been searching for a good used truck. Finally today I found one. A 1999 2500 with about 83k on her. The only thing that I didn't like was that it had a 4:11 rear end. I have really been looking for a 3:55 for fuel economy reasons. When I test drove the truck the tach was turning 2k at 60 mph. It still had the stock tires and wheels.
I was thinking I could mount a taller set of tires on the stock rims to change the gear ratios a little. I believe a friend of mine mounted a set of 305s on his stock rims. so this should lower my rpms by about 2 to 3 hundred to help out the fuel economy.
any help would be greatly appreciated.
If you plan on towing much the 3.55's suck I have a 98 with 3.55 and anything over 60 the mpg heads downhill. not to mention if it is windy out while towing. the 4.11 can get 20mpg if you stay at or under 65 and the truck is sutup correctly.
Stock aluminum rims will fit a 305 stock steels are a little narow
What will the truck be used for? Mostly unloaded? Towing? If so, what, and how often?
CaughtinmyGrill
20
06-13-2008 07:07 AM
wit
32
05-17-2005 12:42 PM
rthomse
18
03-13-2005 06:27 PM
reb0957
04-13-2004 07:19 PM
jlasich
23
01-24-2004 01:28 PM
