Help, how tight to you torque l.p. banjo bolts
Old 01-10-2006 | 11:30 AM
Puke's Avatar
I decided to put my new lift pump in this morning.
I noticed the bolts on the old one were not very tight.
I have it all back together now, but am NOT SURE where to torque the bolts. Expecially the banjo bolts. The others I can always keep an eye on.
I know with aluminum it's easy as hell to strip things out, so I thought I would check with you guys to see. (maybe those banjo bolts go into steel????j)
I know I'm paranoid, but About 15 years ago I bought a used full dress harley....about HALF (that's right) of the bolts in the casings, covers, etc. were stripped out (except for the ones in steel) and I ended up buying a full set of heli-coils just cause every time I took something apart I found the idiot had stripped another bolt. Eventually after a few months, it was tight again. ....
I NEVER WANT THAT TO HAPPEN TO MY CUMMINS.
Old 01-10-2006 | 01:22 PM
OlBlue's Avatar
Just snug and a little more - about 18ft/lbs.
Don't over do it or, you can break them. They only need to seat against the washer, and that makes a pretty good seal. Just snug and see if they leak.
Old 01-10-2006 | 02:42 PM
jrs_dodge_diesel's Avatar
Just tighten until snug. Itf it leaks tighten a wee bit more. If you over tighten this happens :
Old 01-10-2006 | 03:08 PM
OlBlue's Avatar
Ouch,
Bet that was fun getting out....
Old 01-10-2006 | 04:19 PM
Scotty's Avatar
Top's Younger Twin
Use new crush washers and if you get it snug, check it. If you are under 16lbs...tighten to 16 and check for leaks. I had one twist ever so slightly trying to get it to 18. I believe it if its a drilled out banjo, its easier to twist off at 18. Heads up.
Scotty
Old 01-10-2006 | 04:39 PM
blackdiesel's Avatar
Registered
BEEN THERE DONE THAT. oh man i was so ticked. it had it around 35-40 ft lbs when she broke. i know, i know im a moron. but 18 ft lbs is a hair more then finger tight. i thought it needed more but that shows what i know.
second time around it went much smoother. i didnt try to give it another lick "just to make sure" it was tight
Old 01-10-2006 | 05:35 PM
Puke's Avatar
Wow,
My banjo bolts don't look like those. Mine have shorter heads, and they appear to be aircraft (300,000 p.s.i) stainless.(due to the color) The heads are machined a little bit oval), From what I've read, APPEAR must be the operative word here. I tightened them before waiting for replys due to lack of patience. I am sure they are more than 18 foot pounds, but how much more I don't know. Now you got me worried that I'm going to be cruising down the highway and ..+!@#$ you know....
Old 01-11-2006 | 01:33 AM
Originally Posted by Puke
Wow,
The bolts in the picture above are tapped bolts for a FP guage. Hence the bigger head. I had a torque wrench set at 12 lbs snap that one. The next one I got and the other hi-flows I just snugged with my socket wrench, and checked for leaks when I ran it. I don't bother with the torque wrench anymore.
That particular bolt I was putting in the VP 44 for my FP guage. It was actually easy to remove the threads still left in the pump after the head popped off.
precision151
11-19-2008 06:25 PM
broncobilly
10-24-2007 03:22 PM
xloudnproud
05-02-2006 10:12 PM
Yukon Dodge
01-11-2006 05:37 PM
rattle_rattle
11-08-2002 09:53 PM
