Help Error Codes
Help Error Codes
Hello, I need some help with a P1693 error code my truck set yesterday. :P I know the code was set by my comp box and is associated with the ECM but I was wondering if there was some way to remove the code without going to the *******?? I was able to get the check engine light to go out with 4 engine starts with the comp box unpluged. Any help would really be appreciated. <br>
Re:Help Error Codes
You can try Autozone.<br>They read and reset codes for free,<br>well most of them do.<br><br>They might not be able to get into the ECM though, just the PCM, and it sounds like you got that one to clear with the 4 starts.<br>Cummins might be the only ones able to dig deep enough to clear the 1693 if it didn't clear itself as well.<br><br><br><br>phox
grunthmc
06-05-2012 10:17 PM
exwrestler
02-05-2010 09:34 AM
sandpuller2004
02-13-2006 01:54 PM
