HELP!!! Can't remove Crank Position Sensor
Ok I've researched till I'm blue in the face.
I've got the starter off, the dipstick out of the way and have hit the sensor multiple times with PBBLASTER and I still can't get it to budge????
I've tried everything(tapping with hammer, pry'ing with screwdriver, twisting with vicegrips) BUT using a dent puller, its kinda cramped, the only dent puller I could get my hands on is about twice as long as the space available.
SUGGESTIONS PLEASE
-Tim
ps: took it to a local shop because I knew this was going to be over my head and they wouldn't even touch it, so I didn' t have much choice but try myself
SUGGESTIONS PLEASE
-Tim
Update: finally removed my old Carter LP (had left in place when I installed my FASS95) this allowed me to get the vice-grips in well enough to TURN the CPS but still couldn't pull it out. Tapped it with a self-tapping screw, just pulled a small chunk of plastic........
Any suggestions before it gets sent to the dealership?? they swear they can pull it, something about a Cummins tech with 15+ years with such things??
but I don't trust dealerships....
-Tim
-Tim
been there done that. if it doesent fall right out you have to go to phase 2. you have to drop the oil pan and push it out through the oil pan, sort of a pain in the rear
something I used to do is pry it with a screwdriver at the same time I was turning it....sounds crazy but it works...sometimes it will break and then all you do is get a screwdriver in along the side of the old one and twist...it will fold into itself and you can pull it out with a pair of needlenose.
I kept heating the end of a screwdriver up red hot and burning a notch about 3/4's the length of the sensor. I then put a wood screw into the sensor (I found hitting the end of the screw to get it started also helped with breaking the sensor's rust seal). After the screw was in, I spun the sensor around and around inside the block then finally pulled it out.
Good Luck!!
Good Luck!!
I've always get the sensor spinning in the block first, hit it with pennatrating oil, then use a small prybar on the metal bracket. Pry on it while spinning it in the block. Haven't broke one yet.
The End of the Story
OK..
I officialy gave up and am a die-hard believer that the Crank Position Sensor is the HARDEST sensor EVER to remove. I finally had to take it to the dealer and it took their "experienced" diesel tech (cummins) four HOURS to remove the sensor. They wouldn't tell me what they did, but I do know it involved a torch and eventually breaking the sensor in half.
New sensor in place and running great.....
-Tim
-Tim
I have been doing the same thing, I have researched and researched. I do not have a diesel, but am working on a 1997 pontiac sunfire 2.2. My research led me to your thread, but same problem. I have been twisting and pulling and tryed needlenose plyers. It is very hard to reach and I can barely fit my arm in to reach it from the top. Can't hardly reach from the bottom. I will have to agree with you, that this is or can be the hardest sensor to replace......I still can't get it to come out. Very fustrating..
Administrator / Scooter Bum
Wait until you try to change a cam sensor on a 24 valve with the VP still installed..........
BTW, when I changed my crank sensor, mine was one of the easy ones to remove.
Cummins Guru
I agree, i sprayed mine to death with nutcracker and WD and spun it back and forth with light pry pressure behind whatever you can find to pry against. I broke a bunch of the shoulder off and when i was about to get a big hammer and really remove it, it just popped out. Its a real test of patience, kinda like a 3 year old with little popping lawnmower toy.
