help?!!
Old 07-31-2006 | 01:29 AM
dodge lightning's Avatar
help?!!
Hi all!!!! Ok i have a 99 dodge 3500 4x4 duelly and have the edge comp module installed along w/ gauges. I recently installed the new in-tank lift pump and noticed since I installed the module when i floor it the fuel pressue will drop to 3 psi and below! I was wondering if i could get the old style lift pump from NAPA and double them up. I wasn't sure if this high of pressure would hurt the vp.
Old 07-31-2006 | 11:54 AM
CTDinMT's Avatar
I don't have an answer for you, but if you post this in the 2nd Gen section you'll most likely get a quicker answer. Good luck!
Old 07-31-2006 | 11:57 AM
help?!!
Old 07-31-2006 | 12:05 PM
Abbynormal's Avatar
I am not too up to date on these models but I KNOW that low pressure is not good. You might ought to consider a Glacier or FASS pump. Someone else will chime in soon.
Old 07-31-2006 | 12:08 PM
Where is the fass kit mounted? Do you still use the stock water in fuel seperator?
Old 07-31-2006 | 12:13 PM
Abbynormal's Avatar
Most people mount it on the chassis rail in front of the fuel tank.
Old 07-31-2006 | 01:06 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I merged these multiple threads together and placed them where I thought you would get the best responses.
Old 07-31-2006 | 01:25 PM
Diesel-Dan's Avatar
Here ya go.... If you do either pumps mentioned, you will need to put you stock pick up back in the tank or do a suction tube kit.
You dont use the Stock Filter head with the FASS....BUT you do with the HPFP.
Old 07-31-2006 | 05:43 PM
Do any of you guys have the stock filter head for sell?? They are discontinued and mine is busted all to hell.
Old 07-31-2006 | 05:45 PM
Diesel-Dan's Avatar
How did that happen? Im sure you can find one pretty easy. At my old shop i used to work at back in texas...we must of had 12 of thoes things sitting around.....
Old 07-31-2006 | 07:13 PM
Angry
I screwed one of the test port plugs in to far and busted it. Anyway I have looked everywhere, ebay, dodge, cummins, junk yards, and on here. I cant find one for anything. I was thinking i could convert it over to the newer style but then i realized it wont bolt up. If you could give me that shops # or find me another 1 it would be greatly apreciated.
Old 07-31-2006 | 08:09 PM
the496rocket's Avatar
pump
My friend just bought an 01 and the vp and lift pump were junk, was still under warranty by 3 months, I work at a chrysler shop and I installed both the vp and in-tank lift pump, like you, the pressure was crap, So I got him an original lift pump as well and I removed the block that goes in place of the old lift pump and put this one on and spliced into the same wires, so now with the in-tank pump and lift pump he runs 25-27 psi idle and 17 wot, no problems yet, really east to do.
Old 07-31-2006 | 08:27 PM
awsome!! Thats what I will do then, thanks alot everyone.
Now the only problem i have is the filter head, anyone have one or know where one is?
kcredneck
07-25-2007 10:11 PM
ollie32
06-06-2007 09:21 AM
2500TurboDodge
07-31-2006 04:21 PM
bkay
11-06-2003 10:39 PM
Quick Reply: help?!!
