Hard/Won't start when hot
'98 24 Valve Cummins' seems to start ok when the truck is cold. However, after it has been running for a while it won't start. I have already replaced the LP and it didn't make a difference. My old lift pump was at about 10PSI's but I replaced it anyways, due to other peoples similar problems. It seems like it is possibly losing prime. Also, when I did the pressure test I also hooked up a clear tube to check for air leaks downstream, yet I saw none. Frustrated, any sugestions?
"Don't make me go to the dealer, please help!"
Any help is appreciated!
Thanks,
Travis
Thanks,
Travis
uhoh
Sounds like your VP may be on it's last legs, that is a common sign.
This sounds stupid but I know it works.
When the truck won't start hot like that, try pouring some cold water onto you VP, I bet it will start right up.
look for tsb's. there is one on that problem. mine is a 99 and i had the same problem. i had to get the computer re-flashed. cured the problem like a charm. i found that tsb on fritz's page.
Techincal
Service
Bulletin
That's what TSB is...as for the link...
Main Page
http://dodgeram.org/
TSB Link
http://dodgeram.info/tsb/index.html
I hope this helps... And welcome to the site...I was once in your shoes...
Service
Bulletin
Main Page
TSB Link
Strjock81
16
12-12-2007 09:53 AM
duallydave
08-07-2005 09:38 PM
