grinding feeling/noise when turning
I've been feeling/hearing a grinding for the last 6 months or so from what seems to be the rear end. It seems to be getting worse. I can actually see the glass in my outside mirrors shaking when I make slow right or left turns. I've changed the fluid twice now in this time span and put in friction modifier each time. What could be causing this? Could there be a problem with the internals of the rear end?
Mark
Mark
i posted this several years ago, here it again......
here`s a new twist on the sealed wheel bearings on my 01 3500 .... (rwd) I noticed a strange noise when turning left, the noise would go away when I applied my brakes. so I figured it`s time to replace at least the front pads. but when I jacked it up , I found a real loose wheel bearing ... fearing the bearing had gone out, I proceeded to dismantle it (drivers side) Imagine my surprise when I started to remove the bearing nut and found it loose !!! apparently the rotation of the forward motion had loosend the self locking nut.... If I had not caught it early on, It could have caused some real damage..... So here`s a word of caution to any body that has a rwd dodge with sealed front wheel bearings------check dhe drivers side nut. the self locking feature on mine failed ----- mileage is about 113K
I had the EXACT same thing happen on mine around 75k
im going thru that same problem.
are you sure its coming from the back and not the front?
mine sounded like the back brakes or axle and i stuck my head out the window with one ear facing back and one facing the front of the truck. the noise goes in and out while turning or braking. deffinately coming from the drivers side front ... either bearing or brakes.
plus it is making tons of heat, after a 30 min drive the front driver side wheel about burned off my finger tips... lol
b.lee,
Before I heard about the hub bearings possibly being the culprit, I just assumed it was the rear end. I haven't tried sticking me head out the window yet. Can you actually hear the noise coming from the front?
Mark
Mark
No, not yet. Just haven't had time yet working 7 days a week lately. Next weekend I'm going to jack up the front end and see if there is any slop in the front wheels. I really don't want to take it to a mechanic since I don't know of any good ones in my area. I'll find out soon and post back.
Mark
Mark
mstep3
05-20-2011 12:07 AM
tom austin
17
08-23-2007 02:27 PM
Mega07
07-19-2007 12:37 PM
